How do I get all surfaces coloured?
SJI
Hello together,
Example:
I have 2 or 10 fitting holes like 10H7.
Could I get the surfaces from this holes coloured very easily? Not by single clicking every surface 😉
So If somebody shows only the modell not the modelltree easy know this holes are!
Thanks 4 ur help.
Greetings
SJI
dgschaefer
(To:SJI)
You can use the find tool to do this.
Set the following:
  • Look for surface
  • Look by feature
  • On the History tab, select number
  • Set the number range for the features that you want
  • Click find now and all the surfaces of those features will be found
  • Select the ones you want, click the >> button to add them to the selection
  • Choose the color you want
LinkedIn
6 REPLIES 6
SJI
(To:SJI)
For Example:
BenLoosli
(To:SJI)
One trick is to color the solid one color, then change the surfaces to another color. When you do a hole or other cut operation, the solid color will be where the cut is.
TomU
(To:SJI)
Unfortunately Creo cannot do this easily or automatically.  You can change your selection filter to "Intent Surface", but you still have to manually pick them.
dgschaefer
(To:SJI)
Set the following:
  • Look for surface
  • Look by feature
LinkedIn
You can also find surfaces of features of a certain type.
For all hole features use the Attributes tab like this:
LinkedIn
SJI
(To:dgschaefer)
Thanks 4 all the help!!!
