Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Try to use full path for both SetFileName() and SetPenTable() methods. There might be useful information in any exception thrown from the application as well.
Updates on this question. I opened a case with PTC which resulted in 2 new articles in their Knowledge Base and some key word additions to 2 existing articles so they are more likely to be found when searching. These are good articles with that also contain the most important items: code examples
The list of articles follows. The last 2 are new and the first 2 were already created when I was having this issue.
