How do I save the CG?
NEALROSENBLUM
All,
I cannot figure out how to save the CG. Iselect ANALYSIS->MODEL->MASS PROPERTIES and I can temporarily see the CG. I just cannot seem to figure out how to save it so that I can see it as I drag a sub-assembly using a pinned connection. I just want to observe the location of the CG as I move the sub-assembly.
(Wildfire 4.0, M070)
Sincerely,
Neal Rosenblum
Geometrix Engineering, Inc.
201 N. 13th Avenue
Hollywood, FL 33019
Ph:954-920-2049
Fax: 954-920-9574
Cell:954-649-9399
<u>neal@geometrixeng.c</u>
In WF3, make sure you switch the dropdown from 'Quick' to 'Feature'.
Then, on the Feature tab, you can choose to have the analysis feature
create a coordinate system at the CG for you. Hope this helps.
Tyler
If you don't want a feature, but just want it displayed so you can spin,
click the glasses icon instead of the checkmark. Silly icon choices,
why would the check mark do the analysis and then immediately exit the
dialog? What good is having the results displayed for a nanosecond?
BTW - The blue arrows button resets the dialog box so you can make new
choices
Doug Schaefer
LinkedIn
