Creo 2 Ok I'm stumped, how to you create an annotation feature of a diameter, all I have been able to create so far is a radius
Double click the feature edge and it will return a diameter instead.
...and welcome to the forum, Bob.
Antonius, thanks, I look forward to collaborating with you and the other users on the forum.
Antonius thanks for the quick reply!
That worked! next question, how do I add a tolerance? It is grayed out in the menu.
Dale, that did the trick! Thanks
