How do you create and annotation feature of a diameter
ptc-2256424
Creo 2 Ok I'm stumped, how to you create an annotation feature of a diameter, all I have been able to create so far is a radius
64004835-001+%28Active%29+I__MBE_MBE+Test+Design_test+parts+creo_64004835-001.prt.25-.bmp
7 REPLIES 7
Double click the feature edge and it will return a diameter instead.
...and welcome to the forum, Bob.
Antonius, thanks, I look forward to collaborating with you and the other users on the forum.
Antonius thanks for the quick reply!
That worked! next question, how do I add a tolerance? It is grayed out in the menu.
Dale_Rosema
(To:ptc-2256424)
Check out this discussion:
http://communities.ptc.com/message/191103#191103#191103
Thanks, Dale
Dale, that did the trick! Thanks
