How do you hide an imported feature?
dellens
7-Bedrock
I've looked through all the options but still haven't figured out how to hide an "imported feature".
If this is possible how would it be done.
I even have a layer with the imported model but the "hide" option does not hide the imported model.
psantos
(To:dellens)
When you import geometry as quilt and not as solid
Can hide in the tree but can also create a layer and
add to this quilt or solid layer and hide
I hope to have helped
Regards
Psantos
2 REPLIES 2
psantos
(To:dellens)
Regards
Psantos
dellens
7-Bedrock
(To:psantos)
Wow, I didn't expect a solution to this issue so soon.
This works perfectly as the imported model is only used as a skeleton framework for my model built from scratch. I will just delete the imported feature when I get all the necessary placement information from it.
