How to Add Tapping Sizes on Creo Drawings
splant
I require to state an M16 tapping size for a hole on my Creo drawing
Any ideas how to do this as I can only get up to M10 within the tolerance tables from model properties
Any help would be highly appreciated
StephenW
(To:splant)
Are you using the hole feature?
Steven,
If you are creating a Standard Hole feature, as indicated by Stephen's image, you will be able to show the Standard Hole Note in the drawing.
Amit
