How to Set, not just modify, Text/Font Slant Angle for drawings.......Wildfire 4.0
johnd59
I'm trying to get my Leroy Font for notes & dimensions on a drawing to automatically be default to a specified Slant Angle.
Where do I take care of this?.......or can I at all?
Regards in advance
In your drawing template go to the Format pulldown and select "Text Style Gallery". Select your default style or create a new one, then choose the "Modify" tab. Set the text angle you want and select OK. Save the template and it "should" work. I emphasize "should".
<u>
</u>
Chris Benner
Autodesk ® Expert Elite
Well, this seems to work on notes, but not dimensions. I've modified my "default" text style. I place a note and the changes show up.... no problem. I place a dimension and the changes do not show up until I edit the text style on that dimension and select the SAME style... then the changes I made to that styke show up. Weird.
<u>
</u>
Chris Benner
