Hi All,
I have a bearing assembly with me in creo. but I am not able to get satisfactory result in Simulate, There is somethign wrong while applying bearing load.Can anyone help me in resolving this issue. I have attached an image file for your reference.
Amit
Amit,
Can you describe your problem with some more detail?
You show an assembly and a several levels of detail finer than one would consider unless modelling a bearing as per your attached image if in the context of a larger assembly. It is possible to study this bearing but often unnecessary.
A Simulate 'bearing load' is an approximation of a load applied to a hole by a bearing and doesn't require a bearing model.
Regards
