How to change arc dimension to diameter dimension?
ptc-5447139
Hello.
I have recently started using Creo 2.0 , and I am already stuck.
In the tutotrial it says , while dimesioning te circle to change arc size to diameter..but how do we go that? 😕
3 REPLIES 3
How do you create a thread?
Click on the Discussion tab above4 and you will see Create a Discussion on the right.
Click the circle twice before placing the dimension with the middle mouse button.
You can also highlight the radial dimension and use the right mouse button to open the menu where you can chose "change to diamter".
