So I am using Creo Parametric 3.0. I have changed and exported my system colors, entity, and model display. I want to have these settings up every time I open a new part. I have no idea how to use the config, or what files I need to change. I am not talking about drawing templates but part templates. Any in depth tutorials I can look at?
Hi Alex,
In order for all your models to use the system colors you saved, you will need to set a config option.
The changes you made to the Entity and Model Display, don't specifically have to be exported to be used. Once you make the changes and click OK on the PTC Creo Parametric Options window, the information is saved to a creo_parametric_customization.ui file. This file is read every time Creo is launched.
You can find additional information regarding the UI file via the following article:
CS37185 - Customization of the User Interface in Creo Parametric
If you don't have a use account, to access the article, you can created one here.
Amit
