How to change the default maximum segment length
ptc-4620431
Iam trying to do a spec driven pipring in creo 2 with schematics. The default "Max Segment Length" is given as 236.7 and i need to change that to 6000. Can someone help me with this.
Now i need to change the value for each segment, otherwise it will get highlighted as a "Segment Violation" in "Pipe Check Rules"
2 REPLIES 2
Hi basil
Just edit line stock
go to second tab (DESIGN RULE)
You can found third row was max segment length there you can change your length.
If any concern let me know it.
Viswanathan.K
Yes.. currently iam doing the same. But then, i have to do it for each and every pipe seperately. Can we give some value, which will be taken by default.
