I am new to PTC product. I need to color different surfaces by different color. These surfaces may or may not be on a single part. Please help me out. In Catia, it is very simple to do that.
Select the View Tab then click the pull down beside Appearance Gallery
Then select a color or click More Appearances to create a color
Click OK and OK again
Then click the surface or surfaces (holding Control Key) and click OK again to finish
Thank you.
