How to control "configurable module" use exist 3D model or make a new one?
Sulibo
After you added a normal assmbly 3D model as a "module variant" in a configurable module ;
When you use "Variant builder" in a configurable product to select the normal assembly;
Normally, Creo will use the exist assembly model to build the new main assembly model( product variant),
But in some cases, the Creo always copy a new model to build the main assembly.
Would any one know :
How to control  "Variant builder" to copy a new one or use exist "module variant"  to build the new product variant?
Thank you!
Sulibo
(To:Sulibo)
The answer is:
If a "module variant" in configurable module with "depandent" relationship with the top configurable product:
The "Variant builder"  will make a new copy for this "module variant" ,
I hope this is on purpose,
But seems little danger while people can easily breake the dependences without warning.
Sulibo
(To:Sulibo)
The answer is:
