Hello
How we could create dimension using common reference in Creo 6 ( in the attached figure it shows for Creo 2)
In Creo 4.0 and probably the same in 6.0, select the base reference, then, holding control key, select all other references before placing dimensions.
Dimension - Common references is o more available as it was merged in Dimension from Creo 3.0. You need to use CTRL for such dimensions.
Thanks, yes it needs to select other references while holding the control key before finishing dimensions placement.
