Hello Community,
i want to use the creo function "compare parts" and Export this Report to a file using VB API.
Is there any way to do that?
In VB API i found no function to create this Report.
Currently i use a mapkey but no Export file can created with a mapkey!
Creo 2.0 M170
Sauter
The problem is solved...
Set the config Option "info_output_mode" to value "file".
Then you can use a mapkey to compare parts.
In the session directory of creo a file named "diff_report.xml" was created.
Sauter
