How to create annotation sets in *.ASM with Creo View?
VeqTor
Hello forum,
I got an assembly here in the form of one *.asm and several *.prt files in one folder.
I can view the assembly in Creo View. However, it seems that I cannot modify or create annotation sets. Also, it does not seem to be possible to export the assembly as *.PVZ from Creo View (to then create annotation sets in the PVZ file).
Or is there any other way to create and save annotation sets here?
Chris3
(To:VeqTor)
ok in that case I think your problem is that you are opening the native CAD and Creo View doesn't support saving annotations to the native CAD:
https://www.ptc.com/en/support/article/CS93630
Can you open it in Creo Parametric and save it as a pvz?
4 REPLIES 4
Chris3
(To:VeqTor)
Sounds like you are using the Creo View Lite version? I don't know what annotation sets you are trying to modify but it could be possible you need a MCAD license:
Creo View version comparisons:
https://www.ptc.com/-/media/Files/PDFs/CAD/Feature-Comparison-of-PTC-Creo-View-MCAD-Product-Suite_DS.pdf
VeqTor
(To:Chris3)
No I'm using Creo View MCAD -- which perfectly allows to create (and save!) annotations -- however only on PVZ files and (seemingly) not on *.asm files.
Chris3
(To:VeqTor)
VeqTor
(To:Chris3)
Ok thanks -- now I see that there is no way to do this in Creo View:
PTC wrote:
Annotation are supported only on Creo View file (eg: PVS or PVZ) and cannot be saved for the native Data (eg: Creo Parametric)
I don't have Creo Parametric, but I can request the CAD data from the developer once again, but then as a PVZ file.
