Hi..
I want to create copy geometry of multiple parts in one single part ( as a single feature), So please can anybody let me know the process / procedure.
Prashant Pandarkar
Hi Prashant,
When you are in the part mode you can go to Model > Get Data > Copy Geometry. By default the Publish Geometry will be selected.
If you have any Published Geometry in other models, you can bring those into the part. Otherwise, de-select the Publish Geometry and select the Open Folder icon. This will allow you to select any other model.
After the model is selected, click on the References tab. Here you can select Surface, Chain or Datum references to add from the referencing model, into your existing part.
Repeat the creation of the Copy Geometry feature for all the desired models.
Amit
