How to created the family table in assembly drawing
ptc-6653371
Hi all,
there's an question distracting me.
Suppose we have a cube, and it divided into two part, top & bottom,
I can create the family table and setting the parameter(dimension) in the parts drawing,
but when I follow the same step to create the family table in assembly drawing,
I found out that "I can't select the part drawing's dimension as the parameter" in the assembly drawing,
what I want to do is to change the dimension(length*width) in family table directly, then we got the different outline dimensions in each instance,
I'm sure it's pretty easy to you guys. I'd welcome some advice.
Simon
Add each part to the assembly drawing, Set/Activate each part in turn and add a Repeat Region for each part.
Sorry, I can't catch your meaning,
what should I do next after setting each part in turn?
