How to display value dimension instead of name in the display annotation box
fbwdraftman
Hello!
i have a question please.
I am not sure that it is possible, buf if  yes, it would be great!
How to display value dimension instead/ in addition of value name in the "Show Model Annotations" box.
Thank you
It is possible, but for that you need assign name to diemnsions at part level. (As in below images).
E.g. In part mode select dimension > Right Click > Properties > Enter name
Part ModePart ModeDrawing modeDrawing mode
Hello.
Thank you for your answer, it may help even if it is not precisely what i wan't to do.
Best regards and thanks again.
Thanks, mark the post as solved, if got the solution.
