How to do pipe end treatment in creo piping?
Copper pipe end requires Converging/diverging profile at the end depending on the fitting size. Also the pipe end made it round using pipe end forming techniques. is it possible to do pipe end forming methods in creo piping?
Below images are the anticipated shapes (Created in different CAD system, not in creo)
I don't think there is. You can make a "fitting" for the desired end style and install it to the end of the tube. We use a flared end on a lot of our tubes, so we just added a separate view of the flared end and specify for the tube maker to allow enough extra tubing to flare the tubes.
Hi @HC_9153653,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
