referring the article CS392162, I'm not able to edit the name of the folders.
In my example I need to add the mechanica beams and I want to maintain the original ones.
I already create the folder structure, as you can see in the image attached:
- simulate
- steel_beams_mm_mechanica
- steel_beams_inch_mechanica
I want to change the label of the folders:
- SIMULATE
- MECHANICA MM
- MECHANICA INCH
I need it in two different languages, english and another one.
Thanks in advance
Hi @Armando_Pirlo ,
how did you modify your afx_custom.txt text file?
Maybe this will also help you to understand how the customization needs to be done:
https://youtu.be/-iLYU-YT8e4?si=L-5LDfymiBw5naD5&t=434
Hi @Armando_Pirlo ,
Hi Samuel,
thanks for the link.
I solved with your indications.
My error was the customization_path option definition.
