Hello guys,
I would like to know if it's possible to apply a filter to a specific parameter within a table, as in the following example:
I have a family table of bolts that includes various diameters and dimensions. My goal is to automate the generation of the 2D drawing using the rpt region feature, as follows:
My version: PTC CREO 10
unfortunately, I can't imagine exactly what you want to achieve.. Please provide more details (use pictures). If it is possible create sample Creo files and upload them.
Filter in Creo works differently.
You can create a Common drawing of the bolt with "d", "L", "D", "H"
The table would list the Part numbers of the Bolts with Dimensions. The way one sees in a catalog.
Filter does not work like Excel Filter.
It is not clear from your question but this is what I assume you are trying to do.
You have a family table of bolts that contains various sizes for diameter and length etc.
You want to create a tabular drawing for each bolt size i.e. diameter of bolt. Hence the request to filter the table by parameter.
You can create multiple drawings that reference the same generic bolt model and apply a different filter to the repeat region on each drawing. However this is a strange way to do things.
If you really want a tabular drawing of each size of bolt it would be better to split the larger family table into smaller family tables, one for each bolt size.
Or create a nested family table. Where the top level generic contains the family table of bolt sizes i.e. diameters and the sub-family tables contain all of the other dimensions e.g. lengths etc.
You could then create a tabular drawing for each instance of the top level family table.
You would do this by creating one drawing, performing a save-as on this drawing and substituting the drawing model with another instance.
Rinse repeat etc.
