How to get part/assembly name from custom Symbol instant. I want part name when I delete symbol using ProDtlsyminstDelete(ProDtlsyminst *symInst). Is there any API or Work around to retrieve part name?
ndaslaniya
7-Bedrock
ProError DeleteBalloon(string strTempItemNo)
ProError status = PRO_TK_NO_ERROR;
int nSheets;
status = ProDrawingSheetsCount((ProDrawing)gblObjCurMdl,&nSheets);
for(int i=0; i< nSheets; i++)
ProDtlsyminst *symInsts;
status = ProDrawingDtlsyminstsCollect((ProDrawing)gblObjCurMdl, i, &symInsts);
int totalSyms;
status = ProArraySizeGet(symInsts, &totalSyms);
for(int j=0; j< totalSyms; j++)
ProDtlsyminstdata dtlSymInstData;
status = ProDtlsyminstDataGet(&symInsts[j], PRODISPMODE_SYMBOLIC, &dtlSymInstData);
ProDtlvartext *p_vartexts;
ProLine w_prompt, w_value;
int size = 0, text_size = 0, k;
status = ProDtlsyminstdataVartextsCollect (dtlSymInstData, &p_vartexts);
if (status == PRO_TK_NO_ERROR)
status = ProArraySizeGet ((ProArray)p_vartexts, &text_size);
for (k = 0; k < text_size; k++)
status = ProDtlvartextDataGet (p_vartexts[k], w_prompt, w_value);
char chrTagName[1000];
ProWstringToString(chrTagName, w_prompt);
if (strcmpi(chrTagName, "index")==0)
//Index Drawing Balloon Data
char chrIndexNo[1000];
ProWstringToString(chrIndexNo, w_value);
if (strcmpi((char *)strTempItemNo.c_str(), chrIndexNo)==0)
status = ProDtlsyminstDelete(symInsts);
//Here I want part/Assembly name from "symInsts".
//Please provide any api or work around.
break;
ProMdl curMdl;
int curSheet = 0;
status = ProMdlCurrentGet(&curMdl);
status = ProDrawingCurrentSheetGet((ProDrawing)curMdl, &curSheet);
status = ProDwgSheetRegenerate((ProDrawing)curMdl, curSheet);
return status;
Read the API Wizard for ProDtlattachGet.  You need to analyze the attachment type before unpacking the ProSelection object.  It may not be populated based upon the type.
6 REPLIES 6
You can retrieve this information by getting the symbol instance attachments.  Use the following functions:
1. ProDtlsyminstDataGet
2. ProDtlsyminstdataAttachmentGet
3. ProDtlattachGet
Then you can retrieve the model item from the ProSelection object.
Hi Patrick Williams
Thanks for your response.
But I am getting -2 Error in ProSelectionModelitemGet.
Here I attached Sample code for the same.
ProDtlsyminstdata symInstData;
proErr = ProDtlsyminstDataGet(symInst, PRODISPMODE_SYMBOLIC, &symInstData);
ProDtlattach attachment;
proErr = ProDtlsyminstdataAttachmentGet (symInstData,&attachment);
ProDtlattachType type;
ProView view;
ProVector location;
ProSelection attach_point;
proErr = ProDtlattachGet (attachment, &type, &view, location, &attach_point);
ProModelitem p_mdl_item;
proErr = ProSelectionModelitemGet (attach_point, &p_mdl_item); //Here I am getting – 2 Error.
ProName objmdlName;
proErr = ProModelitemNameGet(&p_mdl_item,objmdlName);
Can you help for correct result.
Thanks in advanced.
Thanks for your support
You could try ProDtlsyminstFeatureGet() to get related feature and then ProFeatureSolidGet()
