How to get the value of a parameter in a family table instance with VBA?
cstarnes
I have an Excel sheet that lists all of an assembly's components, and a "Part Number" parameter for each component. My problem is, the parameter isn't read if the component is a sub-assembly, or a part that is an instance of a family table.
Does anyone have an example of how to check if the component is a subassembly or FT instance, and if so...how to get a parameter value from it?
Here is a code snippet of how I'm reading the parameter from every componet (which works if its a part)
    For iCnt = 0 To (pathArray.Count - 1)
            Set eachPath = pathArray.item(iCnt + 1)
            Set mdl = eachPath.Leaf
            ' if model is part
            If mdl.Type = EpfcModelType.EpfcMDL_PART Then
                  iRow = iRow + 1
                  Range("Components").Cells(iRow, colFileName).Value = mdl.Filename
                  Set paramOwner = mdl
                  Set params = paramOwner.ListParams()
                  For i = 1 To (params.Count - 1)
                          ' Get part number and extrusion
                          Set param = params(i)
                          Set paramValue = param.Value
                          Set paramName = param
                          If paramName.Name = "PART_NUMBER" Then
                                  PartNumber = paramValue.StringValue
                                  Range("Components").Cells(iRow, colPartNumber).Value = PartNumber
                                  Exit For
                          End If
                   Next i
               End If
            End If
    Next iCnt
cstarnes
(To:TomasLoun)
The problem was I was starting at index one on a zero-based array (ListParams).
Seems to be working now.
2 REPLIES 2
TomasLoun
(To:cstarnes)
You have there condition
so it cannot process nothing else but parts.
What is in the pathArray list? How do you get this list?
Tom
cstarnes
(To:TomasLoun)
