How to have different serial no of same component
ptc-5312052
Hi
I am using a family table library. I want to have different serial numbers for the same component in different assembly in same working directory. Is this possible.
huggre
(To:ptc-5312052)
Hi
Yes, you could define the component as a flexible component.
And then, change parameter values (serial number) for each assembly where the component is used.
From a PLM perspective it does not make sense to include serial numbers into a design document.
But that's a different discussion all together 🙂
Hugo
1 REPLY 1
huggre
(To:ptc-5312052)
Hi
Hugo
