SUMMARY - Alternate ISO "default" View
dgschaefer
Thanks all and Jeff's doc (attached), this will do nicely.
This should be a onetime thing, not something I need to share with the team or do repeatedly.  This part is molded 40 degrees off of how it is assembled.  It was built, as it should be, in the "as assembled" orientation, but I want the drawing iso views to be in the "as molded" orientation.
LinkedIn
0 REPLIES 0
