Hi everyone,
I am a user of CREO Parametric 12.4.0.0 Academic Edition.
I created a quite complex multi assembly model and, while regenerating it (Operations > Regenerate), I get this message saying that some reference loop has been created. :
1 CIRCULAR REFERENCE LOOPS FOUND
LOOP # 1
Depth of loop is 4
Feature number 26 (COMPONENT, id = 78)
in model ASM07-Z-PLAMA-HEAD refers to:
Feature number 7 (COMPONENT, id = 44)
in model ASM07-Z2-ASSEMBLY refers to:
Feature number 4 (COMPONENT, id = 40)
in model ASM07-Z-PLAMA-HEAD - circle closed.
I understand what a Circular Reference Loop is, but I am not able to locate the features and/or components, based on the information given in the in the message.
So my question is : How can I highlight the components and feature that create this reference loop ?
Thank you for any help !
Yves
You can add the Feat ID column to the Model Tree by doing the following;
Or, you can search for it by selecting the ID like this;
Hi Arnold,
Thank you so much for your efficient and precise help ! I really appreciate and I found my problem thanks to your help 👍
I wish you a merry Christmas !
Yves
Glad that I could help.
Merry Christmas!
Arnold
