How to make a tab your default tab Creo 2.0
asmith-3
I have created a tab for my model and drawing and I want Creo 2.0 to open up with this tab pre-selected not like the layouts tab in the drawings.
AJ,
First tab in UI will be default active tab. Move up the custom tab when customizing the ribbon.
6 REPLIES 6
AJ,
I already have the new tab I created as the first one on the list, but for instance when I open a drawing the layout tab is always the tab that is activated when any drawing is opened. Now I want to make the new tab I created to be the initial tab that is activated when I open a drawing, model, or assembly. How do I go about doing this?
You need to add that tab in all modes seperately i.e. Part, assembly and drawing
I have already done this. But, when I open each there is a different activated tab that the one I created. I want to be able to go straight to work once I open each format without having to activate the tab I created. How do I have each format have the tab I created and saved activated upon opening each format?
Can you upload *.ui file?
I cannot, but I can uplaod screen shots if that will help.
