In Creo 4.0, how do you make a component cut out from parts in an assembly?
on Model tab click Component > Component Operation > Boolean Operations. Set Boolean Operation = Cut.
MH
MH
Little more detail (I'm slow). I performed the sequence then selected the component I wanted cut, followed by the component that was being cut out. I got nothing. Do I need to have something highlighted before going into that sequence? I must be missing something.
Disregard, I figured it out!
Thank you very much Martin!
VH
Hi Victor,
You may mark Martin's reply to post as correct answer.
