How to open a New Assembly Sheet in Creo using VB.NET
avijayan-2
Hai All,
          I have written a code to open a creo session and set working directory using vb.net. and the code was working fine for me. now i trying to open a blank new assembly sheet using VBAPI
But i am getting some error, and i not able to get pass it, i went through the document but didnt get any help.
I am pasting my code over here.
Imports pfcls
Public Class Form1
    Private asyncConnection As IpfcAsyncConnection
    Private basesession As IpfcBaseSession
    Private descModel As IpfcModelDescriptor
    Private descModelCreate As CCpfcModelDescriptor
    Private model As IpfcAssembly
    Private session As IpfcBaseSession
    Private Sub Browse_Click(sender As Object, e As EventArgs) Handles Browse.Click
        OFD.Title = "Creo Parametric"
        OFD.FileName = "xtop"
        OFD.InitialDirectory = System.Environment.CurrentDirectory
        If (OFD.ShowDialog() = Windows.Forms.DialogResult.OK) Then
            CreoPath.Text = OFD.FileName
        End If
    End Sub
    Private Sub btnBWD_Click(sender As Object, e As EventArgs) Handles btnBWD.Click
        FBD.SelectedPath = System.Environment.CurrentDirectory
        FBD.Description = "Select Creo Parametric working directory."
        If (FBD.ShowDialog() = Windows.Forms.DialogResult.OK) Then
            txtWD.Text = FBD.SelectedPath
        End If
    End Sub
    Private Sub Start_Click(sender As Object, e As EventArgs) Handles Start.Click
        Dim asyncConnection As IpfcAsyncConnection = Nothing
        Try
            If CreoPath.Text = "" Then
                MsgBox("Please enter path to Creo Parametric executable", MsgBoxStyle.Critical)
            Else
                Me.Cursor = Cursors.WaitCursor
                asyncConnection = (New CCpfcAsyncConnection).Start(CreoPath.Text, ".")
                If Not (txtWD.Text = "") Then
                    asyncConnection.Session.ChangeDirectory(txtWD.Text)
                End If
                Me.WindowState = FormWindowState.Minimized
            End If
        Catch ex As Exception
            MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
            If Not asyncConnection Is Nothing AndAlso asyncConnection.IsRunning Then
                asyncConnection.End()
            End If
            'lblStatus.Text = "Error occurred while starting new Creo Parametric Session"
        Finally
            Me.WindowState = FormWindowState.Normal
            Me.Cursor = Cursors.Default
            Me.Refresh()
        End Try
    End Sub
    Private Sub NEW_01_Click(sender As Object, e As EventArgs) Handles NEW_01.Click
        descModelCreate = New CCpfcModelDescriptor
        descModel = descModelCreate.Create(EpfcModelType.EpfcMDL_ASSEMBLY, "123.asm", Nothing)
        model = session.CreateAssembly("123.asm")
    End Sub
End Class
the session which is highlighted in red is where i am getting trouble. Please help me to crack this
With Regards
Aghil.M
Hi Aghil,
what error message you recieve?
Tom
avijayan-2
(To:TomasLoun)
Hi Tomas.
     Thanks for the reply, i got the solution for this.
and sorry for the late reply. i have posted a new question if you know anything about it, please guide me on that.
With Regards
Aghil
ok
