How to pull all driven dimensions into a table
agalpin-2
I would like to be able to pull all driven dimensions from a model into a table.
I know that @Dxx (where XX is the dimension ID) will pull individual dimensions through, but is there a way of using a report parameter to populate all driven dimensions using a repeat region?
I have tried to use Excel analysis but it doesnt seem to be able to export all driving dimensions in one go. Even using the search tool to select does really work properly.
I've seen there is toolkit programs available but surely these is an easier method?
on drawing you can find Driving Dimensions or Driven Dimensions using Search Tool. Unfortunately you cannot put them into the table. Special application is probably the only solution.
MH
Martin Hanák
