How to reinforce a limited-length bevel weld?
sellis34
I need to join two plates at a right angle to each other using a bevel weld reinforced by a fillet weld.  The bevel weld is only located in the middle of the join and does not extend the full length of the joint surface.  I can create the bevel weld, but I cannot create the fillet weld on top of it (see image A).
If the bevel weld extends the full length of the joint surface, then it is possible to create a fillet weld on top of it and combine the two welds (see image B).
What needs to be done to create a fillet weld on top of a bevel weld with defined end points (limited length)?
4 REPLIES 4
RobertH
(To:sellis34)
Strange, because it should be possible.
Did you select the top surface of the bevel weld as one of the two surfaces of the fillet weld?
@RobertH
Yes - that's exactly what I did.  I tried selecting it as a surface and as a quilt, neither would work.
Glad to see that it can be done!
I've attached the files of the test model I've been using.  BEVELWELD2 works (bevel is created out of a full-length chamfer), BEVELWELD3 does not work (bevel is created out of a partial length chamfer).
Can you notice anything different in the definition of my welds to your welds?
RobertH
(To:sellis34)
I can't open the files probably due to different Creo versions (we have Creo 4.0).
Thanks - I appreciate your effort to help.
Yes - these are Creo 5.0 files.
Maybe that's the difference: Bug in Creo 5.0?
