How to rename HARNESS in Creo Cabling
Yogesh.T
What is the step / way to rename HARNESS in Creo Cabling. See image attached.
THANKS IN ADVANCE!
Yo
Hi @Yogesh.T,
This is the answer and confirmed via Help Center - To Rename a Harness
You will need to do this from the assembly level. After confirming the new/keep name from the Assembly, the Assembly Rename window opens, allowing you to keep or rename the components within the assembly.
Mike
8 REPLIES 8
Dale_Rosema
(To:Yogesh.T)
If you open the part, can't you just click on it and rename it?
Dale_Rosema
(To:Dale_Rosema)
Or Alt-F, F, R
Alt F (Open File)
F (Manage File)
R (Rename)
Dale_Rosema
(To:Dale_Rosema)
Just make sure that everywhere that this part is used is open when you do this or it will break the relationship to all the other assemblies.
Yogesh.T
(To:Dale_Rosema)
I wish it could be that easy as for all others in Creo. This one tricky!
Hi @Yogesh.T,
Mike
Yogesh.T
(To:MikeBennett)
Worked! Thank you.
Dale_Rosema
(To:Yogesh.T)
...or are you trying to swap out a part for another part?
Yogesh.T
(To:Dale_Rosema)
No
