What is the step / way to rename HARNESS in Creo Cabling. See image attached.
THANKS IN ADVANCE!
Yo
Hi @Yogesh.T,
This is the answer and confirmed via Help Center - To Rename a Harness
You will need to do this from the assembly level. After confirming the new/keep name from the Assembly, the Assembly Rename window opens, allowing you to keep or rename the components within the assembly.
Mike
If you open the part, can't you just click on it and rename it?
Or Alt-F, F, R
Alt F (Open File)
F (Manage File)
R (Rename)
Just make sure that everywhere that this part is used is open when you do this or it will break the relationship to all the other assemblies.
I wish it could be that easy as for all others in Creo. This one tricky!
Hi @Yogesh.T,
Mike
Worked! Thank you.
...or are you trying to swap out a part for another part?
No
