I am trying to import an assembly created in Creo Parametric into Creo Illustrate. Appearance of the part files have been set using the Appearance Gallery in Creo Parametric. However, once the assembly is imported to Illustrate, the original appearance is lost and different colors get applied to the parts as compared to what is present in the Creo Parametric. Is there any solution to retain the appearance while importing.
Regards, Sanjib
Sanjib,
I think that Creo Illustrate accepts simple RGB colors, only. It does not accept textures, bumps, and so on.
Martin Hanak
