How to retrieve a deleted model from my work space
tejo
2-Explorer
Hello there,
I was working on a design which I have created multiple versions of it. I have saved till the version 2 in windchill but I have finalized version 4 and made the required program for it and forgot to check back into windchill, also I have deleted it from my work space. Is there any possible way that I could retrieve that version 4 model back into my work space?
-Thanks in advance
1 REPLY 1
STEVEG
(To:tejo)
As long as you have frames being creating you should be able to go back to that point.  Then you can export out of your workspace that model if you need to go forward to the original spot in the frames.
