Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I have detail that I need to re-engineer on this part. Ideally I would like to create a boundary blend including the light blue line as one of the boundaries. The problem I'm having is that I'm not sure how create a spline that will connect the light blue line to the dark blue surface. The vertical black splines do not intersect with the light blue line.
-- Carl Lever Yorkville Sound TEL: 905.837.8550 ext. 222 FAX: 905.837.8746 clever@yorkville.com
