How to set default normal dimension to default basic dimensions in sketcher
sdara
2-Explorer
How to set default normal dimension to default basic dimensions in sketcher.jpg
3 REPLIES 3
StephenW
(To:sdara)
This is not possible with current functionality. You have to complete your sketch and then edit the properties on your dimensions to make the basic.
sdara
2-Explorer
(To:StephenW)
Thanks for the replay
Yeah, Right now I am following same process
Actually I have do for each dimensions (for every drawing we need to change more than
100
dimensions), so I working on for better process and time effective.
MartinHanak
(To:sdara)
use Find button to select all dimensions. Then go to properties dialog and set Basic options for all of them in one step.
MH
Martin Hanák
