How to show instances in the Open window during an assembly process?
ptc-5072340
Hi All,
I'd like to know how can I show the instances of a family table in the open window during an assembly process, using CREO 2.0.
In WF 5.0 there was an option to do that, but I couldn't find it on the new one.
Thanks in advance.
Felipe
If you right-click in the address bar you should get the browser toolbar options. Before right clicking make sure the cursor is NOT in the address bar. You can do that by clicking anywhere withing the window.
6 REPLIES 6
I think its "menu_show_instances" in the config.pro, set to yes.
And when is this paremeter already set to yes, however the function are still not working? Do you have any idea?
Is this option selected?
That's the point and it's this function that I'm looking for. This menu pull-down disappeared from my window.
Do you know how can I bring it back?
Perfect! Thanks!
