our main CAD system is CoCreate Modeling, and we have a small macro that doe exactly this. Weuse it daily in our large assemblies.Technically, it should be possible in Pro/E by automatically creating a new assembly with only the desired parts. The downside is that the old placement constraints will be deleted. Seehttp://portal.ptcuser.org/p/fo/st/topic=13&post=76990#p76990for a discussion about this.
Jaap
John,
Not sure if this would help, but in Creo Elements/Pro 5 you can create subassemblies from components inassemblies. You can then open them as their own assembly. You can see more here:
http://www.ptc.com/appserver/wcms/relnotes/note.jsp?&im_dbkey=78306&icg_dbkey=826
Doug
