How to update or add start part template for iges model ?
ppandarkar-2
Hi..
Please can i know, how to add or update start part template to iges model.
i.e. We have std some planes, co-ordinate system, std model parameters, relations, combine states etc. which should get apply on iges model either opening it, or after opening or at the time of save likewise..
Prashant Pandarkar
Prashant,
Take a look at this document, you may find it helpful:
CS30943 - How to use a template part or assembly while importing different file formats like IGES/STEP in Creo Parametric
If you are unable to see the article, you can create an account here.
Amit
3 REPLIES 3
Prashant,
Amit
Hi Amit,
Yes, it will help me.
Thank you.
- Prashant Pandarkar
I suggesting setting the config.pro option intf_in_use_template_models  to yes. It will check the box "Use template" by default. If you look in the import dialog, you'll see you can define import profiles. Those profiles are customizable where you include which template to use upon importing. For example, import to a "inch" part or to a "mm" part.
Here we made mapkeys to automate the process.
