How to use CREO software to create animated videos?Do you have any information to recommend?
You can do this with mechanism function. You have to change the connection type in assembly.
For example, for a rotating part choose pin. After that, go to applications, mechanism.
Add some servo motors and than do a mechanical analysis, than choose playback, now you can export as a mpeg video.
Hi @Aurelian
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Hello @Aurelian,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
