I am making a table for drawings and need to use "⏚" (electric ground) in this.
I am unable to find it anywhere in Creo and if I try to copy/paste it I just get at square (□). Weirdly enough if I copy/paste this square to a text editor I get the ⏚ symbol again...
I now I can insert a symbol like this into the drawing but not into the table or a note.
It seems like the fonts in Creo does not support this standard unicode U+23AD symbol which is weird to me.
I am using Creo 4.0 M30
1.]
I copied ⏚ character into Word 2010 document. It was displayed using MingLiU font.
2.]
I searched C:\Windows\Fonts directory and found mingliu.ttc file
3.]
mingliu.ttc file is not recognized by Creo, Creo knows TTF files, only
4.]
I converted mingliu.ttc file using https://transfonter.org/ttc-unpack website
I downloaded zip file containing 3 TTF files. See attached file.
5.]
I put PMingLiU-02.ttf into C:\PTC\Creo2_M070\Creo 2.0\Common Files\M070\text\fonts directory (Creo 2.0 M070 installation)
6.]
I launched Creo 2.0 M070, created a note containing ⏚ characters and assigned PMingLiU font to it. Now I can see ⏚ character.
This may be font related. Make sure you have a font available in Windows font directory that supports the unicode character set and use that font inside Creo when creating the note.
I have had things where if I type directly into the cell, it doesn't work, but if I right click and go to properties, I can then add it. Things changed when the went to WYSIWYG (what you see is what you get) typing.
1.]
2.]
3.]
4.]
5.]
6.]
So it seems the issue is simply that the standard fonts in Creo does not have the symbol.
This may solve similar issues for me in the future as I often have drawings with these squares comming from countries that use special alphabets e.g. Cyrillic.
Seems I was a little too quick to accept this as solution.
I have copied the font to the font directory and I can use the font in Creo. However on my drawing the symbol still shows up as a square...
In the Editor however it is show correct...
I have copied the font to the font directory and I can use the font in Creo. However on my drawing the symbol still shows up as a square...In the Editor however it is show correct...
what font is set on Text Style tab in Note properties dialog box ?
Installed the font Quivira.ttf which have the U+23AD character for ⏚ and it worked with this font.
This means your answer was correct all along but for some reason the font chosen differs...
Thanks for the help.
