How to write mathematical equations in relation dialog box, such as cuberoot, cot, tan, cosine etc??
srajbhar
Hi All,
Let take is a parameter(d1), ds,g1 and toe...
now i want to write equation for below farmulaes, how can i write, please suggest...
regards & thanks!
Shravan
Gotta put that 1/3 in parentheses. Operator precedence.
27^1/3 = ( 27 ^ 1 ) / 3 = 27 / 3 = 9
27^(1/3) = 27^0.33333333 = 3
8 REPLIES 8
BenLoosli
(To:srajbhar)
It should all be explained in the help section under expressions.
I am not sure about the cuberoot value.
TomU
(To:srajbhar)
KenFarley
(To:srajbhar)
R1max = 0.505 * d1 + 0.069*d1^(1/3)
ds = p * cos ( tau / 2 ) / sin ( tau / 2 ) - 1.04 * g1 - 0.76
The only term I'm not sure of is the fractional "power", "^(1/3). I've never had need to use such an expression. You should also take a look at the reference materials people have suggested. The syntax is similar to most programming languages with respect to operator precedence, etc.
All "variables" above ( such as "tau", "d1", "R1max", etc.) are assumed to have been defined as parameters or model dimensions.
srajbhar
(To:KenFarley)
It worked! thanks!
This sounds like an excellent case for using an embedded Mathcad worksheet instead of Relations.
Mathcad Express is free from PTC, and no additional licenses are necessary to embed a worksheet. This functionality is available from the Applications tab.
Dave Martin - dmartin@creowindchill.com - https://www.mcaeconsulting.com
jhaston-3
(To:srajbhar)
Unless I'm mistaken, these equations are of fundamental importance in the urine extraction process.
Or as we call it in Scotland, taking the piss!
RoyCrerar
(To:srajbhar)
Hi, for power and root functions the format is ^x and ^-x, so cube root will be ^0.333 or ^1/3
