I need drawing proprogram
JAK
7-Bedrock
7-Bedrock
I tired but not working.I need to know about how do drawing proprogram,So tell me what is the procedure.
Hello @BenLoosli
 Thank you for information,  I have edited
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
10 REPLIES 10
Here are some tips (sadly I'm on WildFire 4)
First you will have to create a "Drawing State"
"Tools" --> "Drawing Program..." --> "Define States" --> "Create State" --> Enter a name for the state, for example "TEST"
Then, you can record the commands that the drawing state must perform, like show/erase dimensions of views.
Last, you will have to write a bit of PRO/PROGRAM to tell when that state must be activated.
"Tools" --> "Drawing Program..." --> Edit Program --> "File Edit"
IF YES
SET STATE TEST
ENDIF
Close the editor, save changes, hit "Done" or  "Done/Return".
Ofcourse you will have to edit the first line (IF YES) to suit your needs. You can use parameters from the model (part/assembly).
Example:
IF HIDE_3D_VIEW == YES
  SET STATE HIDE_3D
ENDIF
Hello Arun,
For your request, I have created this article
Creo Drawing Program to utilize the Same Engineernig Drawing for both US and Europe Manufacturers / Same Engineering dra…
Parthiban Kannan
JAK
7-Bedrock
7-Bedrock
(To:PARTHIBAN_K)
That document not in link,Shall you send Again that document,how to do drawing proprogram
Hello @JAK
Sorry for the inconvineance, My database was corrupted some days ago. I working on that, it may take some times to reactivate that link
Parthiban Kannan
JAK
7-Bedrock
7-Bedrock
(To:JAK)
Thank you Teun Ham‌ & Parthiban Kannan‌.It was very helpfull to me.
[sgrb_review id=4]
Can you use the same engineering drawing for the US and Europe Manufacturers?
Most of the US Manufacturers follows the Third angle projection and Most of the Europe Manufacturers follows the First angle projection.
Here we have to send the same casting drawing to the both supplier with their requirement.
Creating multiple drawings for the same model is a bad Idea. During changes in the model causes update required for all the drawings
So create same drawing to use both First angle and the Third angle projection
I am going to control the drawing based on the model parameter named SUPPLIER and based on the SUPPLIER value the drawing will update the view state.
If the Supplier value in parameter is "USA" then the drawing view state in Third Angle Projection otherwise it should be in First angle projection
CREATE MODEL AND ADD PARAMETER
Front and Back View of the Casting Model
Create the 3D Solid Model. Here I have created the casting model shown in the figure
Go to the Tool → Parameter
Create a New parameter named SUPPLIER and Set the Value EUROPE
CREATE DRAWING AND PLACE VIEWS
Now Create the Drawing for the model and place the General View and the Default Projection Views of the model (My Default Projection in Third Angle)
CREATE VIEW STATES
Go to the Tools → Drawing Program
Select Define States
Create States named FIRST_ANGLE and THIRD_ANGLE
RECORD COMMANDS FOR THIRD ANGLE VIEW STATE
Now record the commands for THIRD_ANGLE
Go to Drawing Program → Define States → Edit State → THIRD_ANGLE → Record Cmds
Select Views and move the General and projection views as per Third Angle Projection
The adjusted Projection View for the Third angle
Click Done to complete the Record Command for THIRD_ANGLE State
RECORD COMMANDS FOR FIRST ANGLE VIEW STATE
Now repeat the same steps to Create FIRST_ANGLE State
Go to Drawing Program → Define States → Edit State → FIRST_ANGLE → Record Cmds
Select Views and move the General and projection views as per First Angle Projection
The adjusted Projection View for First angle
Click Done to complete the Record Command for FIRST_ANGLE State
APPLY THE CONDITION / LINK WITH MODEL PARAMETER
Let us control the states via the Parameter using If condition in the Drawing Program
Go to the Drawing Program → Edit Program → File Edit
Just write down this code with your notepad editor.
IFSUPPLIER == "USA"
 SET STATETHIRD_ANGLE
ELSE
 SET STATEFIRST_ANGLE
ENDIF
Here
SUPPLIER is the Parameter we created with the model
USA is the value for the Parameter SUPPLIER
FIRST_ANGLE and THIRD_ANGLE is the States we have created with Drawing Program
That's all
Now just change the Model Parameter SUPPLIER Value to USA which results the drawing automatically change it state to First Angle and for other parameter value results in Third Angle state.
Thank you
Parthiban Kannan
BenLoosli
(To:PARTHIBAN_K)
This is wrong! Most US drawings are Third angle and european drawing are First angle.
Hello @BenLoosli
Parthiban Kannan
JAK
7-Bedrock
7-Bedrock
(To:PARTHIBAN_K)
I want to control part in asm drawing.
For example A,B,C are parts in D.asm..
Now D.drw,I no need of A.prt details and i wont show related A.How to do in drawing program.
manjunathrv
(To:JAK)
In which condition you show the A.prt details on the D.drw?
