Is it possible to publis Pro/E objects in IGES format by setting up a CAD worker ? The output should be IGES and not pvz or HPGL.
HI Dave,
are you refering to the #Advanced > # Misclenious > Drawing Options int he recipie file ?
Please check the attached screen-print. it dosent have IGES listed.Moreover the requirement is to have the app Pro/E objects .PRT, >ASM to be published in IGES format.
Any quick way to accomplish this ?
Rakesh
In Reply to Dave McClinton:
Yes, you can set this in the recipe file
Dave
Hi Vaibhav ,
We can achieve your functionality by using "Pro-E dBatch".It requires high end customisation skills if you want to integrate it to your Windchill.If not you can execute it via UI console of the dBatch.
Sriram
Thanks Sriram, but i was looking for a simpler method... a smaller customization may be..
Vaibhav
In Reply to Sriram Rammohan:
Hi Vaibhav ,
Sriram
