I saved some parts as "IGES" so that I could modify the assemblies and transform this assamblies to part. But when I try to open again this new "Parts" tells me it is impossible to open them. A problem is occurrying, it has happed a lot of times. I hope I can find a solution, since it was too much work.
Thanks a lot for your time.
Hi Garcia,
Can you provide the exact error message given when trying to open the IGES files? It might be in the Message Log.
"Koppel_2.igs" kann nicht abgerufen werden
I searched this message (also its translation, "can not be retrieved") but its too broad to narrow down a resolution. This is a good candidate for opening a Tech Support case.
