Here are a couple options we use for exporting high quality TIFF files:
! TIFF Export
tiff_compression G4
tiff_type mono
We also have a mapkey (for WF 4 but should work on WF2) that we use to bump up the dpi:
mapkey tiff @MAPKEY_LABELTIFF File Generation;\
mapkey(continued) ~ Command `ProCmdUtilColorsSys` ;\
mapkey(continued) ~ Select `color_scheme` `MenuBar2`1 `MenuScheme`;\
mapkey(continued) ~ Close `color_scheme` `MenuBar2`;~ Activate `color_scheme` `Scheme2`;\
mapkey(continued) ~ Command `ProCmdModelPrint` ;~ Select `print` `CascadeButton1`;\
mapkey(continued) ~ Close `print` `CascadeButton1`;~ Activate `print` `TIFF`;\
mapkey(continued) ~ Close `print` `CascadeButton1`;~ Select `print` `SheetsRadio`1 `All`;\
mapkey(continued) ~ Activate `print` `OK`;~ Activate `Print_file` `OK`;\
mapkey(continued) ~ Close `color_scheme` `MenuBar2`;~ Activate `color_scheme` `Reset`;\
mapkey(continued) ~ Activate `color_scheme` `OK`
Hope this helps.
Michael Braaten
Senior PLM/CAX Systems Analyst - Synthes, Inc.
