Hello, I try to import/open dwg and dfx files with Pro Engineer 4 as assemblies. They are displayed well and I can also open the different parts, but it is impossible to change the several parts. For example I can´ t add a drilling to the parts and I can not cut off Material of the parts. Do anyone know a way for importing or converting dwg and dfx files to ProE, so that I can also change the parts of the assemblies and cut off material? Is it maybe easier to construct the models with ProE by myself than importing dfx or dwg files? Thank you in advance.
